Graham71
Hi all
Am in the midst of redoing an en suite and have a couple of queries I could do with some advice on!
Have attached a picture below of my wall! Flooring is done using back buttered powder cement - all good I think! Am using the same cement (mapei Fast set) on the walls too.
Right hand side of picture is tiled onto aquapanel as inside shower enclosure... Lefthand side is toilet and cabinet.
As you can see it's painted with what I guess is either silk or bathroom paint.... Do I need to key score sand or remove ??
The plasterboard below is normal, primed 4:1 and tiled so again hopefully all OK... The other question is grout based... Have bought premixed - will that be OK for both areas or is there a reason i should use powdered grout??
Any advice much appreciated!
The white blob on the wall is where I stuck a random cutoff to test... It held pretty firm but on iously didn't bond with the plaster underneath probably more just the paint!!
FYI tiles are 30 x 20 x 9mm ceramic
Thanks in advance !
Thanks in advance !
