N
November57
Hi. I really need one advice. My husband has just spent the last 3 days laying a Victorian floor. However now the tiles are lifting. Obviously the tile fix is wrong. It would appear to have stuck onto the ply but he lies themselves have nit stuck. What would be the best product to use to stop this happening.
Re: Victorian tiles lifting
Can you give us more details. What adhesive was used. What thickness ply. Primer ?
As much info as possible please.
How thick is the ply and is it adequately fixed down so there is absolutely no flexing? The timber floor the ply is fixed to should be checked and improved before the ply is fixed and the ply screwed (not nailed) down at a maximum of 100mm centres. If the substrate (i.e. the floor and the ply) is insufficiently stiff, flexing will loosen the tiles. A grey cement based floor tile adhesive must be used – you can buy some that are described as “flexible” or use an additive on standard adhesives, that will allow for a small amount of movement. Special primers can also be used on the ply to maximise adhesion, but that doesn’t sound like a problem here. If the ply is flexing to any great extent, I’m afraid the tiles will come loose whatever adhesive you use.
Victorian floor tiles lifting
Best Floor Tiles
November57,
swanman,
November57,
swanman,
