Discuss Victorian Tiled Path Concrete Slab Joints in the Canada Tile Advice area at TilersForums.com.
Spud
Not sure why you were advised to put expansion joints in so frequently,there isn't actually a bs standard which states how often expansion joints are required externally most bay sizes are generally 8m which generally follows the internal guidelines , if you have good ground and 100mm thick pour you should be okay without one ,
Are there any big trees or conifers near the path ?
robhdg
london
jimthetiler
sorry meant to say you can tile over joint but decouple the tiles that cover the
joint in the concrete.You can do this by using a rubber tape which you can glue over the expansion joint in the concrete useing a flexi adhesive.Wedi do a tape
for their boards but it is not cheap,if you cant find rubber tape use your imagination.
Reply to Victorian Tiled Path Concrete Slab Joints in the Canada Tile Advice area at TilersForums.com
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
Hi everyone, I’ve a fairly basic question I thinks, hope someone can help me out with. I’m...
Hi, I have acquired Victorian mosaic floor tiles that I am wanting to reuse to tile my exterior...
gamer1
I plan to lay a circa 8m x 4m patio using a concrete slab and fixing with tile adhesive. The...
6K
london
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
