"voltage relay" instead of RCD ?
  • Thread starter Thread starter Stu435
  • Start date Start date
So I'm getting my flat in Kyiv (don't ask...) done up.
I'm using quite experienced builders who have their own tradesmen. Now when it came to electrics I had two main questions: 1/ sizes of the cables on each circuit and 2/ Would there be at least one RCD in use ?
For part 2, he came back and said "RCDs are not very common - we use voltage relays". My search in Ukranian reveals that I think he means this sort of thing:
https://rozetka.com.ua/ua/rele-4673183/c4673183/producer=schneider-electric;tip-247448=rele-napryageniya/
Is this just a breaker of some sort? I see in their electrical merchants they do have main RCDs but I couldn't find any RCBO
I wonder if I should insist he uses at least 1 RCD per CU (flat is on 2 floors and is getting split into 2 flats). But I feel I'd rather know what that "voltage relay" is doing first - if its just keeping the voltage around 230V and isn't for safety then presumably I should insist ?
Continue reading...
Electrical Advice
Tags Tags
None
Stu435,
Stu435,
