Discuss Wall Trowel Size x Tile size in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
If your setting 33cm x 22cm tiles, what trowel size would you use ?
Is 6mm trowel too small ?
In my opinion, a lot depends on how flat your walls are. If they are bang flat , try using a 6mm trowel, put up a few tiles and see what coverage you are getting. If it is not enough, go up a bit.
If the walls are a bit iffy, a bigger notch will help. How thick are the tiles?
Grumpy
Jimmy Boy
Thanx for the advice Grumpy.
They are 9mm thick .. started putting a few up but came across a small bow in the plaster board, think its a stud, nothing much but it meant I had to back butter the next tile a little, so I stopped and was going to pop out and get a larger trowel in the morning but wanted you guys opinion first.
Reply to Wall Trowel Size x Tile size in the British & UK Tiling Forum area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
