Ok, this is what i would do. I'm making the presumption this is yours or a family/friends bathroom.
I would remove all that nasty Silicon that's around the bath at the moment. Then head out and purchase a tube of this stuff:
C-Tec Ltd. CT1 Sealants & Adhesives - Mastic Sealant & Waterproofing Manufacturers - Sealants Online
CT1 is awesome! Fill the bath up with water (if it's plastic, steel baths there's no need) squeeze plenty of CT1 down between the gap, try and get a consistant bead of the sealant all the way round. Press the bath tub back into the corner, any excess sealant that spreads through the "crease" wipe up with a damp cloths, or finger and allow it to set/harden.
You can use the same stuff once this has gone off to re-seal around the top of the bath. If the gap between bath and wall is still "ugly" due to the width of the gap, then i would perhaps make a seal using either a quadrant or corner uPVC bead. Available at most DIY stores.
Unless of course you want to re-tile or remove tiles. But if you do this you're pretty much obligated to unscrew the legs and re-fit the bath. Which is a lot of effort just for a failled seal. Depends also on how fussed you are on the overall look. But some uPVC mouldings can look pretty good.
