http://www.*************************.com/water-underfloor-heating-152-w.asp
Supplying Water Underfloor Heating with a nifty Bronze, Silver (ProWarm Underfloor Heating Systems) and Gold (Polypipe Underfloor Heating Systems) budget system.
Nu-Heat | Nu-Heat underfloor & renewables - http://www.nu-heat.co.uk/
Water Underfloor Heating - http://www.thefloorheatingwarehouse.co.uk/acatalog/Underfloor_Heating_Water.html
Best Price Underfloor Heating | Electric & Water Kits | Floor Heating-Direct - https://www.floorheating-direct.co.uk/
The Underfloor Superstore | Underfloor Heating Suppliers - http://www.theunderfloorsuperstore.co.uk/
http://www.polypipe.com/building-products/plumbing-heating/underfloor-heating/products/overlay
Underfloor Heating | PlumbNation.co.uk - https://www.plumbnation.co.uk/site/underfloor-heating/
Shop Online - Warm Water Underfloor Heating - Page 1 - uHeat - http://www.uheat.co.uk/warm-water-underfloor-heating.aspx < - FORUM SPONSOR - MAY PROVIDE FORUM DISCOUNT IF YOU PROVIDE YOUR USERNAME!!
http://www.underfloorheatingsupply.co.uk/
http://www.halfpricefloorheating.co.uk/
https://www.floorheating-direct.co....+kits/36-1-kit+-+manifold+with+blending+valve
http://www.thefloorheatstore.com/
Underfloor heating systemsWater underfloor heating
Underfloor heating can be installed under tiled, stone and even carpeted floors
A water underfloor heating system, like its dry electric underfloor counterpart, can also sit beneath stone, tile, wooden or even carpeted surfaces.
It offers a heating alternative to radiators in bathrooms, kitchens, an entire house - or simply a means to warm up a cold floor on an early morning in winter.
But unlike electric underfloor heating, it's more complicated to install, and a lot more expensive - see our advice guide tounderfloor heating costs and installation, where we give you details of how various factors can affect the price, based on speaking to installers.
If you're not a Which? member, you can access our unique advice and trader recommendations on Which? Trusted Traders by taking a £1 trial subscription to Which?.
Water underfloor heating explained
With a water-based underfloor heating system, a series of pipes connected to your boiler circulate warm water throughout the floor to heat the space. Alternatively, you can connect the water underfloor pipes to a solar water heating system.
Because the heat emitted from an underfloor system is more evenly distributed than a single radiator, the system can use water at a lower temperature. So it's a more efficient way of heating your home.
Underfloor heating is generally associated with stone or tiled floors, but you can fit it in a carpeted room - you'll just need to ensure that the carpet and underlay isn't so dense that it stops the heat moving upwards (a tog of no more than 1.5 is a general rule of thumb).
Water underfloor heating costs
A water underfloor heating system is more expensive to fit than an electric one, in part because it's more complicated to install. The price can also be affected by a number of factors, such as whether the room you want it in is on the top floor or near the heating system.
The Energy Saving Trust says water underfloor heating is typically more energy efficient than radiators and therefore less expensive to run. But how much you save on your energy bills over time will depend on how energy efficient your home is.
Our guide to underfloor heating costs and installation gives you more details on what you need to consider and what you're likely to pay.
How water underfloor heating works
Water underfloor heating systems best suit new-build constructions
Underfloor water heating works by connecting pipes laid under the floor to a manifold (essentially a central system to connect pipes together) and then to your heating system. It will also be fitted to a thermostat so that you can regulate the temperature.
The floor should be properly prepared and insulated to make the system work efficiently. There needs to be enough space to accommodate this and the piping, so you might have to elevate the floor level. This isn't always possible if you're retrospectively installing underfloor heating to an existing bathroom or kitchen. And even if it is, this will increase the cost.
For this reason, water-fed systems are best suited to new floor constructions. Then the floor itself can be designed to hold the pipework, and be adequately insulated to ensure the heating doesn't escape downwards.
Unlike using ready-to-roll electric mats - which confident DIYers could lay themselves - installing a water underfloor system should ideally be fitted by a professional. This is because it's a more complex process.
You can find recommended heating engineers or underfloor heating specialists in your area using Which? Local.
They'll be able to advise you on the best type of underfloor heating for your room size and shape, as well as what will need to be done to the floor. They will also need to test your boiler to check it can support the system.
More on this...
- Don't pay more than you need to for energy - check you're on the cheapest gas and electricity tariff
- Have you considered getting a stove? See our wood burning stove guide
- Check that underfloor heating is right for you with our underfloor heating pros and cons
