Discuss Waterproof or Marine ply? in the British & UK Tiling Forum area at TilersForums.com.
Brad
hi all
firstly, thanks to all of you who have taken time out to answer my questions! good on ya!
I have another......i don't quite understand the difference between marine ply, exterior grade ply and waterproof ply. waterproof ply is cheaper than marine, so is it ok to use waterproof instead of marine when you need a waterproof substrate to work from?:huh2:
grumpygrouter
WBP Ply or exterior grade (same thing I think) is what is normally the most cost effective surface for tiling. I have never heard of waterproof ply though. Marine ply is named because it was developed for boatbuilding. It isn't "waterproof" otherwise it would not need protecting from the elements, just that the resins used in it's manufacture do not breakdown in contact with water so is more sutable for marine use.
If you need a waterproof surface to tile on then you need to think about "Tanking".
Reply to Waterproof or Marine ply? in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hi all, probably a pretty common question but I'm going around in circles looking online for a...
Looking for advice on how much adhesive to use. I’ve taken on my first tiling project and found...
L
The shower pan on my all tile 70 year old shower started to leak. I have access the the...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
