Discuss Waterproofing tanking Normal showerr over bath in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
In all honesty, it is really up to the customer. They may not be prepared to shell out for the extra cost. Tanking is something that I always suggest to my customers but so far only 1 has taken up the option, prefering to keep costs down initially and risk potential damage at some time in the future. Doesn't make a lot of sense to me.
In reality, with a tap fed shower head, the water pressure isn't going to be that great so the potential for water to penetrate through the grout or pass a leaky bit is not that great so it may not be a problem.
What are the walls made from?
Grumpy
DHTiling
If it was a power shower then i would recommend tanking...but it also depends on how often the shower is used..not all domestic jobs warrant tanking as they are not used enough to constantly make the grout wet thus causing water ingression...If a customer will go with the tanking then all the better but it isn't necessary all the time....
F
frogeye
Hi - for what it's worth I tanked mine - just the 2 walls directly affected by the power shower.
Used the Bal system. Ran tape in corners and because of basic instructions decided to run tape along edge of bath too. I Silicon bath edge to wall below level of tiles to be on the safe side. Made sure it came in under where tiles would go. All in all very pleased with result.
frogeye
grumpygrouter
Walls are plaster skim. Used Ardex AM100 to reskim 2mm after taking existing tiles off. Thanks for the replies. Will always suggest tanking.
This site is great!
Warm Regards
Howard
Tiling Solutions 4U
Where do you get your AM100 from Howard? it isn't readily available up here where I am.
Grumpy
tysfoot
Hi guys,
I have never done any tanking and ive done a few bathrooms now with showers.
Stupid question coming up.
What is Tanking exactly and how much does it cost if a customer wanted it to cover where the shower sprays
Ive got a trade account for topps and i use Bal Whitestar for where the shower sprays then toppfix Waterproof everywhere else
grumpygrouter
Hi guys,
Tanking is a protective waterproof membrane that is applied to the substrate prior to tiling. It is usually a rubberised type of substance when cured. There are a few different types about. I use Ardex WPC myself. Pretty much paint on and is ready to accept tiling in 2 hours.
If you are using white star, why aren't you using it every where? Don't see the point in changing addy half way through! White Star is probably the best tub stuff you can get.
Grumpy
grumpygrouter
its all about money, if im supplying the mats i know bal is the best out there especially for wetter walls but very expensive. Toppfix is good stuff and alot cheaper.
Where do you get your waterproofing from them and how much does it cost ?
I buy it online and it is about £50 a kit. Still don't see the point in chopping and changing adhesives but that is your chice. I get White Star for £14 which is passed onto the customer. usually they are not aware of your costs anyway.
Grumpy
Reply to Waterproofing tanking Normal showerr over bath in the British & UK Tiling Forum area at TilersForums.com
Hi, We are redoing our main bathroom and looking for a second opinion on tanking. We have bought...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
