Discuss weber adhesive in the UK Tiling Forum area at TilersForums.com.
BoldreChris
That's pretty much the only make I use. The rapid is very rapid - sets hard enough to walk on floor tiles within 2 hours - and the standard is very strong. Both the SPF types are a bit flexible so good for chipboard or under-tile heated substrates.
Definitely not cheap but consistent and reliable. That's more valuable to me. I've tried a few other makes and have always come back to Weber afterwards. Not so impressed with the grouts - happier with Mapei there - but there's not much in it.
The new "low dust formulation" packs are a lot less messy to use and I now don't feel the urge to wear a mask while mixing! Probably still should, though.
I've used the SPF, both rapid and standard, on porcelain, travertine, granite, limestone and gres with satisfying results.
Ken Bruty
1,023
Bedford
I use Weber a lot, and it's very good gear, never have any problems with it, and like Mapei, it's predictable in it's going off behaviour, the standard set is excellent for stone and wall tiles, it has good non slip qualities on walls, I would thoroughly recommend it Dave, and reasonably priced, especially the grey adhesive.:thumbsup: The SPF's are good too with good pot life and workability :thumbsup:
Reply to weber adhesive in the UK Tiling Forum area at TilersForums.com
    • Friendly
I'm having a nightmare trying to establish product info from distributors. For example...
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
Just wondered what would be best? The original tiles had a few hairline cracks from the house...
weber adhesive
