I'm on the understanding that the primers most firms make, are close to the liquid polymers you'd put in a standard adhesive to make it flexible. And more of the polymer stuff is in the types that are two-part mixes.
So I've always been told if you need primer, you need primer, not PVA.
Though reading those, perhaps they're selling it as a simple solution that helps limit the substrate from soaking up all the moisture, when using adhesives that require curing by hydration (so being wet).
Might be worth us looking into this with the firms to clear it up a bit.
