Discuss weberset spf question in the Tile Adhesive and Grout Advice area at TilersForums.com.
SJPurdy
wouldn't use spf on ditra only because if it sticks to the orange the ditra will not work as a uncoupling membrane
"Immediately after the Schluter -Ditra 25 matting is installed, the tiles can be set using the thin bed method and using a bonding tile adhesive that matches the requirements of the covering." Copied from Ditra 25 data sheet (6.1). Therefore as a modified (SPF) adhesive required for the porcelain tiles Shluter are saying to use it!
J Sid
you missed copying
"Using the thin-bed method and following all applicable industry standards, set the tile or stone covering directly on the Schlüter®DITRA 25 in such a way that the tile adhesive becomes mechanically anchored in the square, cut back cavities of the Schlüter®DITRA 25 matting.
notice the mechanically anchored and not chemically fixed.
but if fitting, say gulf stone who recommend a two part adhesive or the TM equivalent as favoured by many members on here, Schluter say you mustn't use these adhesive on ditra due to these adhesives bonding / chemically fixing to the plastic and stopping the product uncoupling.
Also care should be taken if laying tiles "immediately" after laying the ditra. un-cured adhesive sticking the ditra mean tiles can't be lifted without pulling the ditra up.
Reply to weberset spf question in the Tile Adhesive and Grout Advice area at TilersForums.com
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
I have recently laid around 30msq of porcelain floor tiles in our kitchen. The tiles have been...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Tile Adhesive Trending Topics
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
