I
Imdad
Hi Folks. Like most others I've arrived here because I'm at a quandry as to what to do with a tiling job.
I had a nice shower cubicle (50" x 30"); a resin tray on a 3" x 2" frame. (With a sliding door on one side).
Unfortunately, through slow seapage of water through the shower tray/tiled wall boundary, I had water make it's way to the lounge downstairs (nothing major, but my wife noticed a stain).
I had a look and the bottom row of tiles (sitting on the tray and sealed with standard bathroom sealant) had sunk down about 3mm from the row above along the wall. The tiles had moved away from the wall and the shower tray had sunk!
I took the bull by the horns and have removed the shower tray completely (had to cut it out as it was wedged in) to reveal a lot of rotten timber (the wall-side 3" x 2" had become rotten).
I now want to turn the area into a wet area and make a sill to the one side that doesn't have a wall. This is in order to leave the sliding door where it is and stop water getting everywhere.
I have laid (screwed down) 2 plywood sheets each 19mm so giving me a very sturdy and even floor (1.5 inches thick!).
Now for the questions:
If I put some timber to make the sill, will I be able to water-proof and tile the sill?
In order to make the whole area waterproof, do I need the tank room - I've had a look and there is a section on this. I asked at Bee & Pue about this and they looked at me like I'd just escaped out of an asylum. The reason I ask is this - if I put down a layer of waterproof tile adhesive (suitable for timber flooring) won't this do the same thing? And once the whole thing is grouted, doesn't this also waterproof it?
Lastly, I want the water to drain out of a hole in the corner of the room (used to be the exit hole for the original pipe when there was a shower tray there). Is this a good idea? If I cement round the hole using cement and grout, will this do the trick?
There are probably dozens of you out there shaking your heads in disbelief, but if anyone has tried this and succeeded/failed, I'd like to know what you learned. And whether any of this is worth attempting!
Failing all that, should I get some of the membrane being recommended elsewhere on this forum? How easy is it to apply to timber?
Thanks! Any advice greatly appreciated, but especially so if based on personal experience of trying something like this!
Imdad
Imdad
