Guest viewing is limited
Tiling Tool Suppliers
Discuss Wet cutter chipping final part of cut? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
dtd00
Hi,
I am new to this and have a wet tile cutter. It seems to be working brilliantly for 99% of the cut (8mm ceramic floor tiles) but on the last part of the cut it keeps cracking the finish and chipping the corner off.
I am trying to feed the tile slowly through the cutter but I am not sure whether I should be doing something different at the end of the cut? Should I be cutting upside down etc?
TIA,
Dan
Admin
Staff member
5,083
1,323
Staffordshire, UK
Hi,
Try not pressing so hard near the end (the blade should feed itself through the tile pretty much through the whole tile - just a little pressure is required) but also try cutting 10mm into the tile one end, then turn the tile around and cutting the rest of the tile to meet the small cut you made.
Welcome to the forum. Thanks for signing up. :)
Reply to Wet cutter chipping final part of cut? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
  • Sticky
Popular Tile Cutter Threads
    Votes: 5 5.7%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 22 25.3%
    Votes: 13 14.9%
    Votes: 27 31.0%
    Votes: 3 3.4%
    Votes: 2 2.3%
    Votes: 18 20.7%
    Votes: 14 16.1%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 3 3.4%
