Discuss Wet, dry or grinder..........???? in the Australia Tiling Forum area at TilersForums.com.
Skinszo
Hi everyone,
I've been let down by my tiler and I need to get this project finished and as there's not loads I'm about to do the tiling myself.
ive got a 10mm porcelain tile to look forward to.
I wanted to get a cutter that will do me well on this job but also something I can use on more in the future now. (Fed up of being let down)
i dont want want to spend fortunes but I know with anything you do get what you pay for.
I want to get something that deals with porcelain as this seems to be what most my customers have now.
so what's the best options, a wet cutter, will a dry cutter cut it ha or as my previous tiler used a diamond blade on his grinder which never gave great cuts.
thanks
Q
Qwerty
A decent wet cutter will probably be your best bet. I can use all three on a porcelain job easily for different cuts. All depends on your budget and also what sort of cuts you will be performing (plunge cuts for sockets, envelope cuts for a wet room former, visible cuts around window reveals etc).
A decent blade is essential on any diamond wheel cutter & grinder. I suspect your tiler had a poor blade or clumsy cutting or both.
+1 with this advice, but whatever route you take..........buy a decent blade as the odds are that the one that comes with the machine will be cheap and nasty and will not give you a good result. Bearing this in mind your cheapest option would probably be a angle grinder (you've probably got one of those) and a good blade. (be prepared to pay £50 - £70 pounds for that). Hope this helps.
A angle grinder with a decent blade would not take any longer than any other form of cutting. Personally I find the angle grinder more versatile than anything else. it can be used for straight cuts/plunge cuts for sockets etc circular square or anything else/curves for shower bases/circular holes of any size. Hopefully it would never happen but if ever I had the choice of just one tool to do a tiling job..............100% angle grinder.
Reply to Wet, dry or grinder..........???? in the Australia Tiling Forum area at TilersForums.com
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hi all, I’m after a new hand held wet & dry saw cos my dewalts had it, and been looking at the...
I have a wet tile cutter and am about to use it quite a lot as have loads of cuts to do and...
Tilers Forums on FB
