Discuss Wet Floor Leaking in the Canada Tile Advice area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
I,ve had a problem like this before on a wet room that I had done,first thing poured water over the floor no leak,then poured water on to the walls no leak, it turned out to be the shower control,might be worth checking that.
I started reading this thread last night and was thinking along similar lines. Its quite a wide water mark down the wall. You say it leaks when water splashes the wall. Have you checked its not a leak on the outlet of the valve? Which ill presume is built in?
Reply to Wet Floor Leaking in the Canada Tile Advice area at TilersForums.com
Hey All, Last week, contractor installed wall and floor tiles and am now seeing...
Wet Floor Leaking
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
