Discuss wet room decs/trays in the UK Tiling Forum area at TilersForums.com.
i was going to use tilesafe glad i didnt firstlt very expensive and secondly you have to rely on the backing to stick personally i prefer to rely on my own sticking methods
Have had one failure with a linear wet dec. Novellini customer care was less than helpful, to the extent that my supplier will no longer deal with Novellini.
Tile safe membrane is folded over channel recess and there sealent used all got lots of give i am surprissed does look so much better than envelop cutting but pleased for your input all the best BazIt would appear that the failure was due to the drainage channel, when fitted into the wet dec was not supported by the ply below it due to the wet dec being slightly deeper than the drainage channel by a couple of millimetres. Over time the channel flexes very slightly as people stand on the metal grille while showering. This in turn breaks the seal between sealant, tilesafe and wet dec allowing water to penetrate under tilesafe. Problem possibly compounded by cleaning materials used to clean shower.
Reply to wet room decs/trays in the UK Tiling Forum area at TilersForums.com
