Discuss Wet room floor advice in the UK Tiling Forum area at TilersForums.com.
Bushwhacker1
Hi All,
Ive got my first wet room floor coming up and would like some advice on setting out.
Its a concrete substrate sloping down to the drain at one end which i intend to tank (WP1 kit) before tiling. BTW, im picking the WP1 approach because ive used this kit several times and am very familiar with it
My question relates to how to set out the tiles to accomodate for the slope? Im assuming i need to run diagonal cuts from each of the four corners?
Any help would be greatly appreciated.
Thanks all
Bushwhacker1
30 to 50mm fall seems a lot just how wide is it from drain to walls sounds like you will have to envelope it you can try centering tiles in line with drain but it depends on how it works to walls try to eliminate slithers if you can also try turning waste on diagonal to tiles if its a square waste
Thanks Jay - like i say, im guessing on the fall so it may not be anywhere near what i imagined
Reply to Wet room floor advice in the UK Tiling Forum area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
