N
NickMizen
Hi! We have just had a semi wetroom installed (tiled shower floor, but with shower screen). The wall and floor tiles are porcelain, with the floor tiles having been laid on marine ply over the dry floor, and a moulded base with drainage laid under the tiles at the same height as the ply for the wet shower area. This was installed approx 3 weeks ago. A flexible grout was used that can be submerged in water. Not sure what adhesive was used.
In the last week the grout has, I think, started to leak. When you stand on the tiles the grout "bubbles", which I presume is water that has got under the grout being squeezed through. Or is this just flexible grout being flexible?
My Tiler has scrapped some of the grout out, and replaced with a non-flexible grout. But the same thing has started to happen again.
Any ideas on what I need to do to rectify this? I don't want the area to leak into our kitchen, but know that if I need to take the tiles up and re-do the adhesive then I will ruin the moulded shower base - very costly!
Any advice would be very appreciated.
