Wet room problem
geordie2013
Hi guys.
Got a problem with a wet room.
Its tiled floor to ceiling but every time customer uses wet room he is left with condensation on the ceiling which if not wiped after every use turns mouldy. He sealed the ceiling with sealer then painted it again but after 2 weeks mould starts to appear.
I suggested maybe a bigger fan in wet room.
Is there a special product for use on wet room ceilings or is there any way around this problem thanx
Is there such a thing as anti-fungal paint? This may remove the discolouration but the moisture is still there, bigger fan should help.
you need a shower light extractor [DLMURL]http://www.screwfix.com/prods/25652/Heating-Cooling/Extractor-Fans/Shower-Light-Extractor-Fan-100mm[/DLMURL]
these work well in wet rooms, i have installed a number of these this year
What-ever-you do,do not tile it as someone suggested.It would probably be okay but there is always a chance of something coming detached then you have a problem if someone is injured.Also the condensation would become a bigger problem
May also help if the area above the wet room is insulated......................Oh......and a stronger extractor
