Discuss Wet room questions - Novellini Duodeck 3 in the Tanking and Wetrooms area at TilersForums.com.
Chris Preston
Hi there,
Read quite a few threads and still have a few questions.
I'm fitting a Novellini Duodeck 3, and then insulation, ufh, slc on floor outside deck. Then tank everything.
I've seen comments both ways about tanking over or under ufh/slc. Pretty sure both will work fine but happy to be corrected?
What would be the best tanking system here, recommended is RIW tilesafe but seen bad comments on here about it. Should I use waterguard, or bal tankit or wpc? Will the bitumen based membrane suffer from ufh?
Many thanks for any help.
Reply to Wet room questions - Novellini Duodeck 3 in the Tanking and Wetrooms area at TilersForums.com
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
Heeelp!!! I've seen some old posts about this but nothing recently. I have 120sqm travertine...
Hi All, First time poster and tiler here. Hoping to get a bit of advice on tiling a wet room...
Hi All over from the electrical forum, was hoping you may be able to give me some advice. i am...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
