F
Flintstone
not something i recall being talked about before on here? Does anyone wet shim studs etc when boarding a wall if there’s unevenness, a stud set back from the rest etc?
Discuss Wet shimming backerboard in the Canada Tile Advice area at TilersForums.com.
With the studs being raw timber that is still moving I thinkIf you are boarding onto studs with backerboard and say a stud is bent 7mm out of plumb on one corner you apply a bed of adhesive on the stud where needed and put the board up get it level then screw up fully once the adhesive has set.
A plasterer watched me using packers and adding bits of timber to crap studs once. He told me his method is to just screw boards on to the crap timber and then dot and dab 9 1/2mm board on to that to get it bang on. Not something I've done before but it made sense, it's not going anywhere and can imagine it would be super fast.
Thoughts?
It's funny how a good tiler can get over things whereas if the tradesman in front of us was good we wouldn't have to get over their poor workmanshipUnfortunately it’s where we are at in the construction industry for a long time now.
Each trade has issues with the one before and lots have the it will do attitude. You have to throw it back to those in charge of standards or get on and overcome.
How often do you here - a good tiler would get over that - so check first, price it right, and if you want it do it.
When using packers do you guys screw them to the studs or stick them?
Reply to Wet shimming backerboard in the Canada Tile Advice area at TilersForums.com
