Discuss Wet Vs Dry Drilling in the Canada Tile Advice area at TilersForums.com.
Concrete guy
It really depends what you're drilling. Assuming this is for porcelain then there is very little to beat the electroplated holesaws and a sponge on a cost per hole basis as they are disposable.
Some of the more expensive water fed systems (like Marcrsits for example) are ideal if you've got hundreds of holes to drill regularly, but can be a bit overkill for the average tiler.
On the occasions when you need to drill dry then there's always a compromise between cost of bit and number of holes it will produce. As a rule of thumb drilling dry is always going to shorten the life of any bit.
Vacuum Brazed Diamond bits designed for drilling marble also work in Porcelain to a reasonable degree. The smaller ones have wax filled centres to disperse heat.
moomarine
did wet for years with no problem, then I tried a dry bit for the grinder and now do all dry.
as for cost per hole I have no idea but find the grinder a lot quicker.
I would have to dig out the wired grinder as my 18v Dewalt grinder is only 7000rpm which is too slow I believe for dry hole saws.
Concrete guy
That would probably do just fine, but a corded grinder would probably do better. Some of the cordless non branded grinders are now so cheap we have a number of customers that bought one just for holesaws and box all their bits in with the cheapie grinder to save taking blades off their their regular machine each time the wanted to drill a hole.
The M14 threaded dry bits are designed to run at 10,000 rpm but we have customers that use an M14 to Hex adapter and fit them in drills. Not recommended but it works, particularly in marble, travertine limestone etc.
moomarine
So you reakon 7000rpm would be OK then? What would it do just reduce the life of the bit?
Concrete guy
I'm not sure it would reduce the life, just drill the holes 30% slower.
The way these grinder bits work is speed and diamonds. Just don't lean on them, let them cut through themsleves.
Reply to Wet Vs Dry Drilling in the Canada Tile Advice area at TilersForums.com
Hi - looking for a bit of advice if anyone has experienced this. Hands up I am completely...
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Wet Vs Dry Drilling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
