I
igro49
Hello,
A question to experts. Which model of wetfloor former tray shall I choose if I want to avoid underboarding between the joists? (Sorry if this has been covered before.)
I plan to build a wetroom on the 1st floor. The tray will be resting on timber joists, 400mm apart, with noggins if necessary. I have checked the joists, and they are surprisingly level. I am going to cover the tray with ceramic tiles. I want to get a strong enough tray, for which underboarding is not needed.
First, I was thinking of Impey’s Aquadec. However, I discovered on their website that installation without underboarding is recommended for vinyl covering only; presumably, ceramic tiles are too heavy.
I have found two other options. First, Maxxus from Purus. It is claimed that the tray can withstand 470 kg (against 190kg for the Aquadec) and even for ceramic tiles, underboarding is not required. Second, Tuff from AKW Medicare. It is also said that the tray can be installed without underboarding. However, the load which it is guaranteed to withstand is the same as for Aquadec, 190 kg. Both of them are manufactured from GRP. Are Tuff trays really stronger than Aquadec?
I would appreciate any advice and/or comments.
Thanks in advance.
Igro
Thanks in advance.
Igro
