thenypeacock
I have wetroom installed in a loft conversion. I know that the plumber put in a wetroom deck and waste system from Wickes because he submitted the invoice to me. Later I had to fire him because his tiling and carpentry were so bad. The tradesman I got in to finish the job was generally unimpressed with the standard of the job done so far and re-did a lot of the plumbing.
My problem is that after sustained use of the wetroom you can see water seeping UP between the tiles when you walk across the room. I am worried that water is seeping between the tiles and being trapped by the deck. I suspect that there is too much "give" in the floor which means the grout between the tiles cracks.
How big a problem is this? I am selling my home and don't want to leave a problem for the new owner.
