Discuss What adhesive and spacers? in the UK Tiling Forum area at TilersForums.com.
mattle40
Anhydrite screeds are gypsum, and are notoriously problematic, if it is identified as Anhydrite and thoroughly dry then there is no problem really but I know of a few failures due to improper prep or the fitter not knowing it was Anhydrite.
(although its not as bad these days as I think a lot more fitters are aware)
As soon as I hear "pumped" I think Anhydrite
They develop a layer of latents on the top as they dry,
This needs to come off before tiling, then primed thoroughly as gypsum and cement don't mix well!
Just something to think on ;-)
hello
is it's gypsum based screed I would sand of laitance in the first place before applying primer, with primer you are using I would be better of using gypsum based adhesive, as cement based adhesive reacts with gypsum screed, if you still planing to use cement base adhesive then would recommend to use epoxy based primer, also would increase tile spacers, minimum 3 mm, if screed have some small cracks would definitely recommend of using decoupling membrane, also in big are as yours would make few expansion joints, movement joints should be used to divide the tiled area into fewer areas of no more than 40 sq/metres
good luck with your project ;)
Reply to What adhesive and spacers? in the UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi folks, We're having our downstairs tiles installed soon, about 82m2 of 1.2x1.2m square...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
