Discuss What adhesive for porcelain floor tiles? in the Best Floor Tiles area at TilersForums.com.
spot on grumpyBefore you select your adhesive, you need to make sure your floor is solid. 9mm ply will only add a small amount of additional strength to the floor. If it was me, I would be looking at something like Ardexflex 7001 or Granfix Ultimate Flex if you only want to use a single part system or for 2 part, Bal FastFlex or Mapei Keraquick with Isolastic additive. Bog standard SPF isn't sufficient for 9mm overboarding, IMO.
Reply to What adhesive for porcelain floor tiles? in the Best Floor Tiles area at TilersForums.com
