Discuss What angle grinder? in the British & UK Tiling Forum area at TilersForums.com.
pt44
Most angle grinders seem to feel about the same, from what I've seen. Personally I use an Hitachi - but never used it in the tiling sense. I have a small one and a large one, they are exactly the same as my local tool hire company use - and they can't recommend them highly enough. I figure if they are tough enough for the hire market - then they will be fine for me. My tool company only hire's the best - not rubbish.
Paul
DEWALT
Had some problems with my wet cutter the other day and this left me pretty stuffed, I want to invest in an angle grinder and would apreciate some feedback on makes, models and ones to avoid! Budget would probably be about £75ish,
cjbombero
Hi cjbombero,
What type and make/model of wet cutter do you have and what problems are you experiencing?
I understand the immediate benefits and attraction of using a grinder with a suitable blade.
However I still believe the accuracy and cut finish acheived with a good wet cutter is worth the extra set-up time, even more so on harder and more expensive materials.
There is an obvious need for a serious re-think about the design of all types of wet tile saws (table top, sliding cart and rail/bridge) and I was hoping to better understand your current frustrations?
Thanks,
Roy.
Reply to What angle grinder? in the British & UK Tiling Forum area at TilersForums.com
gamer1
E
Good Evening Folks. I'm going to post a few pictures & would like to hear some feedback from...
6K
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
Dear TilersForum Thank you so much for the outstanding advice and expert information over time...
What angle grinder?
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
