Tiling Tool Suppliers
Discuss What brand of wet cutting blade? in the Tiling Tools area at TilersForums.com.
Hi everyone
I was kindly given an older used Rubi ND180 smart wet cutter, it’s not in the best condition but it works and will do me for a while as I’m just starting out.
I’ve taken the disc out as it needs replacing. I’m just looking for some advice on whether you think stick to Rubi wet cutting discs or are there other brands that are a much better choice? The cutter takes a 180mm disc with a 22.2mm bore.
Any advice would be much appreciated!
Cheers
Dan👍
Tony_C
528
Glasgow
I'd recommend and ATS blade for it, had one in my cutter for over a year now and it still cuts through porcelain and quartz with no issues. That cutter isn't rated well for heavy use on harder materials like porcelain so a better blade will help with that :thumbsup:
Boggs
1,118
Uk
eBay, red turbo thin blades, been using them for a while, mostly come direct from China.
Cheap.
Not had any problems yet.
Runs, hides, takes cover.
Thanks for your help Tony👍
[automerge]1575796021[/automerge]
Cheap.
Thanks Boggs, I’ll have a look into these👍
Reply to What brand of wet cutting blade? in the Tiling Tools area at TilersForums.com
Hi, I am looking at wet saws and only a DIY here but got a few odd shapes to cut. What would...
ShropshireLad
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hi everyone. Tiling my bathroom first time and going well so far! 600x300 ceramics on walls and...
Im going to be tiling my shower room walls and floor with some large format tiles as per the...
Hi Gents, I've got two cutters, a TS-40 and a TS-60, along with a wet saw. However I'm finding...
6K
Tiling Tool Popular Threads
Southampton
What member type are you?
  1. Professional Wall and Floor Tiler
Business Name
DS Tiling Services
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
