N
noob
Do I install my new bathroom suite THEN tile the floor, or do I tile the floor then install the bathroom suite?
Help is much appreciated.
Basically its a new bath, basin and toliet. Im going to take out the old bath, basin and toleit (olive green currently) and replace with a white suite. The floor is currently vinyl lino, with plywood underneath.depends on what you are installing a bit more info please :8:
Hopefully Noob has his bathroom in now. two layers of 6mm won't achieve the ridgidity of a 12mm sheet regardless of how much 'pink grip' is usedif you use a smaller ply i like to use pink grip grip fill :yikes: over the sub floor then screw 300mm centers i use skrim tape over the joints then a small blob of tile cement along them first then tile away
or even use 6mm ply from frunt to back pink grip then 6mm ply left to right there is your 12mm ply screw 300mm centers
I like the bath in first, then tile the floor and walls, finally fit toilet and basin
If the bath is fitted first , take care with the height regarding the bath panel.
