What cutters best for newbie to the trade
I've been using the virtex one for years (domestic work only) and never had a problem.
For me it's all about the blade in it, CPC PRO blade in it now and has sailed through everything.
Considered the ruby nd200 buts its around £230 dearer and for me it was a case of don't change if it works.
It's hard really, I hatred and still hate the virtex wet cutters , I find with a steady hand and a good blade a grinder will do a just as good if not better job .
Tried the grinder on the last job and find it slows me down and I'm just not keen on it.
Wet cutters next to me and with the grinder it's outside to cut or invest in a decent extraction system and I don't know if they are any good tbh.
Would consider getting a curved blade for shower quadrants mind I've mastered the art of doing them and can do it on the wet cutter in no time.
Think the OP is new to the trade, maybe best with a wet cutter as I think using a grinder it may be easier to run of line or chip tiles if doing it for the first time and you will probably be stressed enough lol you could buy a cheap grinder and decent blade as you will need it at some stage and a few old tiles/cuts and practise to see what suits you best
Cheers guys. Will take it all onboard. I have a few boxes of old floor tiles in the garage that I plan on cutting up for practice. Not 100% sure what they are as not looked at them for years but should give me a bit of practice using a few different methods anyway.
Haven't done much tiling as still at the learning stage, but i have found that my grinder has been by far my most used form of cutting. Straight cuts, angled cuts, curves. My rig consists of a verrrrrry basic draper grinder and a cheapy porcelain wheel. Add a grinding cup to the mix for getting rid of old addy and still i've spent less than £45. But would have been very stuck without it.
Richyharvey,
Tile Shop,
Richyharvey,
Tile Shop,
