hi cj..have looked at geo fix and it looks great gear..if the price is right i would deffo go for that product..........here's a bit of a read for you.........dave....
GEO-fix®
Features and Benefits
- Permanent joint unaffected by wind, rain washout and mechanical cleaning equipment
- Brush applied - no special skills or equipment needed
- Non staining - attractive and neat finish
- Up to 20 times faster to complete than traditional methods
- Durable joints which are unaffected by frost, salt UVA and chemicals
- Resists weed and plant growth between joints
- Water and air permeable - allows for continued nourishment of tree and plant roots
- Enables ornate paving patterns and designs to be jointed quickly and effectively
Fields of Application
GEO-fix® Jointing Compound is a quick and easy way of applying a permanent, rigid joint over 5mm wide and a minimum 25mm deep on all types of paving including:
- Natural Stone
- Concrete
- Slate
- Clay
- Terracotta
- Granite
Application Procedure
Preparation of Substrate
Ensure that the paving to be jointed is dry and free from loose dirt, debris, oil, grease, etc. It is essential that joint widths are a minimum of 5mm wide with a
minimum depth of 25mm. Deeper joints can be part filled with dry sand or other dry materials, to the required minimum depth.
GEO-fix® Jointing Compound has superior flexural strength compared to mortar.
GEO-fix® Jointing Compound should be considered for its aesthetic and not its structural properties.
Mixing
GEO-fix® Jointing Compound is supplied ready to use and
DOES NOT require any further mixing or addition of any other materials.
Application
Carefully open the vacuum packed bag and sprinkle
GEO-fix® Jointing Compound sufficient to cover an area of 4-5 m2 (see coverage table below) Using a soft brush, push the
GEO-fix® Jointing Compound into the joints ensuring that they are filled with the compound. To ensure a perfect joint press
GEO-fix® Jointing Compound into the joints with a pointing tool, or compact into joints using a vibrating plate. Top up as necessary. Any residue left on the surface when cured can be simply cleaned off by sweeping with a stiff brush
Watchpoints
Use
GEO-fix® Jointing Compound within 45 minutes of opening.
Protect treated joints from rain until fully cured. Any contact with rain and water before the compound has set will affect the product.
Do not use at temperatures below 0° C or in wet weather.
The jointing should not be cleaned by use of high-pressure washers until cured for 7 days. The distance between nozzles to jointing must be at least 10 cm.
Packaging
GEO-fix® Jointing Compound is supplied in hermitically sealed 9 kg and 20 kg vacuum packs.
Storage
Store in a cool dry place.
Protect the pack from punctures or piercing.
Any exposure to air will start the curing process.
Shelf Life
GEO-fix® Jointing Compound has a minimum shelf life of 24 months when stored in unopened containers in accordance with the manufacturers instructions.
Coverage
The figures given below are
approximate quantities required
5mm joint width 25mm depth10mm joint width 25mm depthMosaic 60mm x 60mm 7 kg m214 kg m2Small100mm x 100mm4 kg m28 kg m2Large400mm x 400mm 1.5 kg m22 kg m2
Technical Data/Typical Properties
Application Temperature Limits0°C to 40°C
Freeze/Thaw ResistanceExceeds BCLR: BM2: 1993
Curing Time6 - 12 hours at 5°C, 2 - 6 hours at 20°C
Strength Development
Compressive Strength
Sand
Cement MortarGEO-fix® Jointing Compound
1 day4 N/mm26 N/mm2
7 days8 N/mm212 N/mm2
28 days13 N/mm218 N/mm2
Flexural Strength
Sand
1 day5 N/mm26 N/mm2
7 days8 N/mm214 N/mm2
28 days13 N/mm215 N/mm2
Health and Safety
*For full information on Health and Safety matters regarding this product the relevant Material Safety Data Sheet should be consulted.
Material - ready for use sand mixture with Polybutadiene bonding agent
Density approx - 1.70 g/cm3
Colour - buff or grey
Storage - Store in cool place out of direct Sunlight
Packaging - 9 kg and 20kg hermitically sealed vacuumed packed foil bags
Joint width - Minimum 5 mm
Min joint depth - with foot traffic - minimum 25 mm.
Min Joint depth - with light vehicular traffic - minimum 40 mm
Working temperature - 0 °C to + 40 °C
Workability duration - * Approx. 45 minutes *.
* At+ 23 °C and 50 % relative air humidity. Higher temperatures shorten working time, lower temperatures extend working times.
