What Do You Use When Polishing Porcelain Edges?
i have a set of diamond polishing pads they do the trick no problem also good for limestones and marbles 80 grit to 1200 grit
can also be used for doing your nails if you want😀
So you're living it up like it's still 1990, basically 😉
Now the only word in that sentence that would impress me more is carbon. But you'd just have tourettes if you whacked it in there mid-sentence because I'm pretty sure there's no carbon involved.
did I say I did the graft my son who is my partner dose the polishing I just check it , if its not correct he dose it till its right they have to learn.
I still "drill holes" with a pin hammer tile nippers because it takes skill. Doesn't matter what the tile type is or the size of the hole. I'll get it as perfect as a drill, first time, every time.
So I see your point pal. Can't beat the hand machine, of, well, the hands.
Close but I was thinking more carbon fibre. Totally different chemical mix. And looks far more sexy than Silicon carbide.
I use an angle grinder and a ball hammer.fast and easy to do no problems
Dan,
Just Rizzle,
Dan,
Just Rizzle,
