Discuss what exactly is a tipped trowel? in the British & UK Tiling Forum area at TilersForums.com.
Thats wot I said....A tipped trowel is a thinbed solid fix trowel...it has small teeth in the main body of the trowel and then a bigger welded tip at either end..
These tips will give a sold bed of adhesive with a toothed comb effect without the combed effect tooth touching the substrate thus leaving a solid bed of adhesive.....they are mainly used for elastomeric adhesives on timber floors...
It is a trowel made by/for BAL specifically for their fastflex adhesive. it has longer 3mm "teeth" at each end of the trowel to attempt to give a solid bed with Fastflex.
Cheers Tony, only ones I have ever seen were BAL ones, hence my assumption they were a BAL thing.They are actually quite common Grumps bal cant take the credit.
They have a hardened metal ball at either end of the blade which regulates the adhesive depth and supposidly doesnt wear down.
Great on a flat floor but of no use on those you generally come across as it wont bring the adhesive to level goes with the contours............
Who Dave....get me down, nah! We are like 2 peas in a pod!!!your welcome, you were right tho dont let that big guy get you down now he's got his big bro to look after him.............unk:
Only his end........Bloody big pod then......................:dizzy2:
Reply to what exactly is a tipped trowel? in the British & UK Tiling Forum area at TilersForums.com
