Discuss What gauge of trowel in the British & UK Tiling Forum area at TilersForums.com.
K
Kenny C
sorry bit of a pain to get flat maybe step it down to an 8mm, also use white spf
Could you explain in a in little more detail please? this is all new to me.Last night I laid out the hole floor and done all my cuts and numbered with a pencil then lifted and ready to go,wanting to make sure I do every thing spoton all the gear was a bit expensive.
Cheers Kenny
MICK the Tiler
Selecting your trowell size depends on a few things.
1, Size of the format ( Larger format larger the notch)
2, thickness of the tile ( Thicker tiles you can use larger notch) ie Thick stone mosaics say 100mmx100mm an 8mm would be ok. Small thin mosaics like glass and vitrified need smaller notches.
Your kit should consist of 6mm 8 and 10 you might need to experiment with a couple to make sure you get good coverage without addy sqeezing up through the joints. A small nailbrush is a great tool for cleaning any stray addy, keeping clean is very important whilst working with stone.
K
Kenny C
Thanks Mick I have already started to put them down stopped a light refreshment. when you say about stray addy, in some of the joints there is stray addy but not seeping above the level of the tile is that ok or should the joints be perfectly clean please don't say yes.Also where I have stopped and scarped up the excess addy from the ply. I have wiped up the floor with a sponge and gave a light hover to lift any loose stuff is it Ok to just start tilling again on that are or do I have to reseal it with sealer? when if first sealed it I gave it 3 coats.
Cheers Kenny
Reply to What gauge of trowel in the British & UK Tiling Forum area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
