Discuss What goes between 17mm Marine Ply and 6mm Hardibacker? in the UK Tiling Forum area at TilersForums.com.
DanC
Hi,
I'm about to replace my floorboards with 17mm Marine Ply and then 6mm of Hardibacker on top before laying tiles.
I thought I just screwed the Hardibacker to the Ply, but apparently I need a layer of tile adhesive in between. That's news to me, is that right?
If so, I assume I need to seal the Ply first too, I've had a look at the Mapei range but none explicitly say for this use, what would you guys use there instead?
Cheers!
DanC
Sorry, you've outed that this is the first time I've tiled...
It's primer I should be asking about isn't it? I'm after ensuring a good bond between the layers, not waterproofing...
Oh, I'm priming the adjacent plaster board with Bal APD but it looks like that's no good for Ply either. I can't find anything that says it should prime Ply OK... this is probably where you tell me I don't need to...
Reply to What goes between 17mm Marine Ply and 6mm Hardibacker? in the UK Tiling Forum area at TilersForums.com
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hi, a long time since I have been here but back for some advice/reassurance ! About to tile my...
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
