Discuss What primer and adhesive - underfloor calcium sulphate in the Tile Adhesive and Grout Advice area at TilersForums.com.
kiteboy
Swansea
Hi all
Just wondering if there are any recommendations for correct primer and adhesive for a kitchen with underfloor (piped) heating on a calcium sulphate screed
Ive was planning on using Bal APD primer and BAL adhesive but Ive just read that BAL stuff is cement based so perhaps no good??
Thought Id ask the question before we start as Ive heared of horror stories or tiles having to be relayed - may as well try and get right first
Thanks all
L
LM
First you need to make sure the floor is dry.
Has the ufh been commissioned properly?
Have you taken readings to check this?
Was the laitance removed?
What tiles are you using?
BAL APD is perfect for this and their adhesive is top notch also, make sure it’s ok for the tile your using and also if you need to uncouple the floor.
Make sure you tile to the correct procedures in regards to the heating of the floor.
kiteboy
Swansea
Laitence being removed soon - its been down 6 months so definitely dry now - yeh its been connected and commissioned. I didnt realize the laitence should have been removed sooner - so doing soon
They will be 600x600mm porcelain floor tiles
Uncoupling - dont know much about that but does that depend on the tile then??
kiteboy
Swansea
Oh hell - thats new - no-one has mentioned that before - its like an underlay then - is that stuck down??? Is there still a need to get the laitence off and prime it still?? Never straight forward - just been googling it - will ask my tiler what he thinks - he didnt mention it thats for sure
kiteboy
Swansea
Seems new that one - cant seem to find anywhere to buy online (in stock anyway) but will have a think and go back to tiler too - just back to the original question is bal primer or bal apd primer the way to go if we stay as is?? Again could I ask for any other recommendations for adhesive ta guys
Will defo run past the tiler though for sure - he didnt mention decoupling at all but kinda make sense to me if I can get it somewhere only need to about 20 square meters
J Sid
You can lay to a wet anhydride Julian?
BAL Flexbone 2Easy is a unique floating uncoupling mat where no adhesive is needed underneath – a truly uncoupled system! Because it is floating, only basic preparation is needed – simply sweep solid, level floors and lay the mat. No remove of residue, bitumen or laitance. No priming needed. Tile immediately to contaminated, stained or cracked screeds and over bitumen. Fast-track tiling on new anhydrite and sand:cement screeds that aren’t cured as moisture evaporates through covering joints.
Reply to What primer and adhesive - underfloor calcium sulphate in the Tile Adhesive and Grout Advice area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Tile Adhesive Trending Topics
Swansea
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
