J Sid
isn't the problem a long time reaction between gypsum and cement where the two touch, could take years to fail ?
Actually I thought it was the other as when both parts were inert ie finished curing that was it . Obviously some things although may not have a good bond from the get go may take time to show the problem . I couldn't see how dry anhydrate and dry cement is going to start reacting maybe @Ajax123 could share some knowledge on this .isn't the problem a long time reaction between gypsum and cement where the two touch, could take years to fail ?
how long was it down?I did an alpha hemi hydrate screed where I had to put a cut tile until the next stage of work was completed . When I had to remove said tile to continue tiling , it didn't want to come up , it was well bonded to the screed and that was done with a cement based adhesive .
At least a couple of years but on a side not I have tiles down in my own house which was a new build . Mayhew alpha hemi hydrate screed been 5 to 6 years and they are fine . Same process . Hallway , kitchen , utility and boot roomhow long was it down?
On a similar note ....I have a domestic customer who had problems with some solid wall plastering issues.isn't the problem a long time reaction between gypsum and cement where the two touch, could take years to fail ?
Reply to the thread, titled "What primer and adhesive - underfloor calcium sulphate" which is posted in Tile Adhesive and Grout Advice on Tilers Forums.
