richiep
Hi all,
I'm a bit confused as to the best way to approach a job in my own house. The house is on the market, and i'm doing my bathroom out so it is more appealing. However, even though i want to move i still want to do a proper job.
I have 2 outer walls that are block, plastered and painted with emulsion. The other 2 walls around the bath are stud walls, plastered and tiled. I will obviously be removing and replacing the whole stud walls, but am not sure whether to replace with plasterboard again or to use something else.
I wish to tile all four walls now, and i'm unsure as to whether i can put tile backer board on walls or not, or even how to fix them as i have not used these products before.
I suppose in short, my question is, can i line all my walls with tile backer board of some sort? If so which is the best to use for 200mm x 300mm ceramic tiles? Or should i line all walls with 9mm plasterboard?
All advice will be greatly appreciated.
Thanks, Rich
Thanks, Rich
