Discuss What sort of primer to coat underside & edges of plywood floor? in the British & UK Tiling Forum area at TilersForums.com.
ojtiler
Thanks to replies to an earlier post, I am re-fitting my new 22mm WBP ply floor with expansion gaps & I will also coat with primer on the underside & edges (to reduce risk of moisture absorbtion).
Can anyone recommend what sort of primer I should be using for this? Sorry if this has been answered somewhere else, but I searched a couple of posts & although they confirm priming is needed, I couldn't find what sort needs to be used.
(The flooring is for a wet-room.... after fitting the ply I will be over-boarding with Marmox and fitting an Impey tanking membrane).
Thanks in advance for any advice.....
Reply to What sort of primer to coat underside & edges of plywood floor? in the British & UK Tiling Forum area at TilersForums.com
Hi, new member here! I'm about to tile the walls and floor of our shower room. The floor at the...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
