What sub base for tiles
Thanks. I've just read something about sealing the underside of the ply. What's the reason for this and does the ply need priming for adhesive to bond to.
Ply needs overboarding for adhesive to bond to. Don't stick tiles straight on to ply, not unless you want to be doing it again very soon!
Just had a lengthy and detailed reply typed out. Decided to delete it. Sad state of affairs. My apologies to Craigo. I hope you find the information you’re looking for. Over and out.
Aye it’s a good idea to seal the underside of the ply as sub floor areas can have a high relative humidity, and by sealing with SBR or similar it will help prevent the ply from absorbing moisture etc.
British Standard states
6.3.4.2 New timber bases New timber bases should be constructed with noggings between the joists. Water and boil proof (WBP) exterior grade plywood of 15 mm minimum thickness should be screwed to both joists and noggings at 300 mm maximum intervals. The lower face and edges of plywood should be sealed against the ingress of moisture using preferably non-aqueous sealers, e.g. polyurethane varnish, or styrene butadiene rubber, to prevent distortion by changes in atmospheric humidity before being screwed down. All junctions between boards should be supported by noggings or joists.
DIY Tiling Forum
Craigo007,
Unused Account 1,
Craigo007,
Unused Account 1,
