10mm round notched trowel for the floor, you will need a 10mm wheel in the cutter score the line with heavy presure use a quick snap action drill problems use diamond tip water cooled, you don't say if the tiles have a thick profile on the back. The deeper it is the bigger notch trowel you will need. Use multiflex adhesive. If polished porcilin then you must seal them first before grouting
