What, straw - i’ve deroofed a garage of a cement / straw flat roof before - i thought you fed straw to horses🤣. Where will it turn up next?Even odder is the straw version!
Oh right, no pva it is then - i was going to use mapei aquadefense where the shower will be any way so i’ll just that everywhere instead - thank you.Ceramics will be fine on that substrate, dont use pva/unibond , use an acrylic primer and a cement based adhesive.
Hi Guys, another newbie here, what weight in kgs per sqm will honeycomb plasterboard walls take please? Paramount Partition wall boards type. I want to fully tile my bathroom walls in 600x300 ceramic tiles but, since finding out the wall structure I am now concerned the walls won’t take the weight - help please.
Yes they are, currently half tiled with 6x6 bog standard ceramic tiles with white emulsion walls. The existing tiles are dropping off and the plaster underneath looks like new (24 year old house). I thought take the existing off, make good if required, Unibond all walls, use Mapei waterproof paint for where the shower over bath will be and then add the new 600x300 ceramic tiles. My main concern is the weight on the paramount walls (new to me) though I see what you may be getting at, as I suppose the skim could break away under the weight? Thank you for your time.
