Guest viewing is limited
Discuss What's the best way to tank a plaster wall in the Canada Tile Advice area at TilersForums.com.
RBussey
Hi all!
i am building a wetroom en-suite and have been doing some research but still can't decide on what materials to buy or what would be best for me. The walls are brick with plaster and the floor has floor boards and joists. At the moment I have decided to get the Tuff2 tray as I have read good reviews about it working well with wooden floor joists. Does anyone disagree?
And with the floor boards as I am tiling should I replace them with ply wood? Or place hardie board over the top?
one last confusion I have is the tanking for the plaster walls? Can I also use the same tanking membrane for the floor?
i am very keen on DIY and feel comfortable to do the job, I'm just a bit unsure which materials to use.
any help would be grateful
Thanks :smilewinkgrin:
RBussey
thanks, at the minute there is backing plaster on the brick walls, which has the water pipes an current mixer bedded in to it. I wish it was a studded wall as my options would be easier! :smilewinkgrin:
if I take all the backing plaster off there will be a big gap to fill for the walls to become even again and then the problem with the water pipes.
do you think I could build a thin studded wall, fix it to the brick wall, then either fit hardiebacker or plasterboard to that?
cheers for all your advice
Plumbing Tiler
Neither did I until I starting digging the other night.
cheers for your help, I will build a small stud wall then fit 6mm hardiebacker which will hold the weight of the tiles and will not protrude too far out of the wall.
thanks again :thumbsup:
Hi, I know it's probably not what you want to hear, but with the size and weight of your tiles you would be better off using the 12mm Hardiebacker 500 boards for your wall, the 6mm is usually just used as an overlay onto existing floors.
Plumbing Tiler
Cheers for the advice, I'd rather find out now rather than later!
this weekend I'm going to see if I can bed the water pipes into the solid wall then il be able to remove the backing plaster and dot and dab 12mm hardibacker
cheers guys for your advice
Dot and dabbing is really only suitable if you're fixing plasterboard sheets, if you are going to use the 12mm Hardiebacker then it would be best to stick to building a stud wall as you first suggested, and screwing the Hardie onto that, have a look at the website it will explain in a bit more detail and hopefully help you out mate, its JamesHardie | HardieBacker® 12mm Cement Board for Walls, don't hesitate to ask on here again if you are unsure about anything, good luck :thumbsup:
Reply to What's the best way to tank a plaster wall in the Canada Tile Advice area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
