Plumbing Tiler
Neither did I until I starting digging the other night.
cheers for your help, I will build a small stud wall then fit 6mm hardiebacker which will hold the weight of the tiles and will not protrude too far out of the wall.
thanks again![]()
Hi, I know it's probably not what you want to hear, but with the size and weight of your tiles you would be better off using the 12mm Hardiebacker 500 boards for your wall, the 6mm is usually just used as an overlay onto existing floors.
