When you choose your wet cutter. don't just go for the cheap range if you can
because a 450w etc motor will struggle with large format slate / terracotta
etc..especially when doing repetitive cutting...a machine that has an induction
motor won't burn out like traditional bush type motors will..
so my advise would be to try and buy machine with a higher output motor
to cope with the demands asked of it..and then accompanied with a good
blade..the macrist mentioned is a great blade..( i use the turbo one )...
but there are other brands as well...rubi have a good selection for every material.
The choice of machine is up to the individual..The plasplug range has a good
choice.. probably the mastertiler would be the best of its range very popular cutter
and can be bought for a very reasonable price..
I use rubi machine's now excellent build quality and powerful motors.. i use the
diamant d200.. 1.2 hp motor and won't struggle on thick stone's..
So my advise is to choose wisley and not just cause it's cheap...
You will find some nice cutters from neil at...
http://www.buybrandtools.com/
Good luck............
