When to use a finishing tool on grout?
Crumbs
Hi, im sorry if this is a stupid question... cant seem to find a clear cut answer on it.
At what stage do you use a finishing tool / dowel or whatever suits for grout lines?
Is it after its dried for 10 mins as that would be when the joints are cleaned if using a sponge? or another time?
Thanks alot. 😀
There is no hard and fast rule. As an apprentice you tend to grout every day for months before you even fix a tile and it's during this time that you can feel/understand the joint drying. The grout has to harden sufficiently enough to stay in the joint at a high level, but be soft enough to take out without 'pulling' an uneven line. The humidity of the air has an important effect on drying and consequently the final polish of the face of the tile surface/glaze. The 'tooling' stick itself is important, and for years before washing off, I used a drumming stick with rounded end prior to polishing with a white 't' shirt!
Happy days!
Thanks guys i will use it just before i sponge (after 10 mins or so) its properly obsolete in the professional scene but us diy warriors use them still 😎 I did try with a sponge but did not seem as consistant compared to a tool.
What the tooling stick does is ensures the grout is pushed fully into the joint and gives a uniform finish to the tile edge. On anything over a 3mm joint it is still an essential part of a Tilers tool box!
Never used one either...
I feel a poll coming on...
John might be a billy no mates..
As I said it's an essential part of a Tilers tool box!😉
You should try it on your Metro splash back tiles to rake out the bevelled edges.
Modern grouts are more reason to rake the joint - they require less water on the surface to clean away any excess thus keeping the consistency of the grout equal.
But what do I know - 44 years of watching people do it their own way!
Billy no mates - your spot on.
Never tried one. When I first got taught grouting, I was shown to go over the joints in a crisscross diagonal direction. That way it doesn't pull the grout out of the joint getting rid of the need to use a finisher.
But I'm gonna try one now, cuz no matter what method or sponge I use to clean the grout off there is still the odd patch that I have to go back an pay a bit of extra attention to to get it right. Need more practice.
Thanks guys, i used a virtex finshing tool in the end, only cost a few £ from screwfix. 😎 But in places it does look like its taken to much grout out, most likely slightly different size lines. The tile above causes light shadows onto the grout lines. Think the tool is likely better suited for smaller gaps.
Any tips on what i can use, i used spacers 3mm for tiling.
Also can i grout on top of it or am i better raking the areas out? Nice one thx 😉
I really cant see how you can get a perfect finish by just using a sponge ,the only time i dont point the joints is with mosaic or most floors ive never been able to get a good finish without ,what about metro tiles ,the same thing ?
Yes. Never ever used a tool. I ensure all joints fully filled at the grouting stage. This combined with attention to detail when wiping down guarantees compacted, even and smooth joints. Yes, even with metros!
Always have the old drumstick to hand, had it since Keith Moon threw it at me for driving his roller into a swimming pool!! Perfect joints every time! 😉
Who ?
No he was a bloke round the corner who played in a miners brass band that got disbanded after Arthur closed all the pits in the early seventies !😉😉
😉Who ?
DIY Tiling Forum
Crumbs,
Andy Allen,
Crumbs,
Andy Allen,
