Where to start (Blank room)
N
newpark7
Hello
I hope this question is not too stupid - but was wondering the following: -
If starting a new project (blank room) do you start on the floor tiling first and then the wall or the other way round?
Does the skirting go on top of the floor tiles or do you tile up to the skirting?
What are the advantages/disadvantages etc, are there any hard and fast rules about which gets done first?
If tiling floor to ceiling how do you finish the top to ceiling gap?
What do you recommend to use as a seal on bath tops and shower trays etc?
Any help appreciated.
Mark
Hello
Mark
Personally :-
Walls first saves getting the floor messed up
Skirtin on last over new wall and floor tiles
Should be cut to the ceiling tidy enough but you can always cove it if not happy after.
Bath seals hell of a questions the only seal I would use and recomend is Sealux of all the seals these seem to of got it right.
Again the above is my personal oppinion, hope it helps
101
Yep.
Walls then floor.
Skirting can be done either way really, ie tile down to, or skirting over top of tiling.
Floor tiles should be a couple of mm's away from skirting, then Silicon the gap for an expansion joint.
If you have a gap at the ceiling then flexi caulk\ decorators caulk fills it if it's quite deep, otherwise use Silicon.
Baths, just run a thin bead of Silicon all the way around.
To expand a little on Fekin re Silicon around the bath.
To Silicon seal your bath cut the row of tiles around the bath a couple of mm short so you have room for a good seal. When these tiles have dried fill your bat to the top with water, then run your bead of Silicon around. Dont empty the bath leave it over night for the Silicon to dry.
When the bath is full of water it won't be that heavy again and the weight pushes it to its extreme, when the bath is emptied it spings back into shape so squeezing on your Silicon creating a very good seal.
That done tidy it up and your done.
101
im with Fekin and 101 on this one,in addition i like to start at the window wall or area where most cuts are just to get them out the way then its the other straight forward walls.
and wear waders or a dry suit:grin:
got to agree with Brian,try and do the fiddly stuff first.Dont want to face it later in the day when your getting tired and are dying to get away.
I would also go for walls first. When there is no skirting,leave the bottom row out until the floor is tiled. One very important exeption to this is when using matching floor and wall tiles where the floor joint has to line up with the wall tile joint. Floor HAS to go down first. Just done one of these.Unfortunately,I was unaware and customer didnt mention that this was required until after i had done the walls. To late then.
Beat me to it len...great advice..when floor and wall have to align....mark out the walls first and transpose to the floor.Tile the floor and then follow the lines up the walls .....not for the feight hearted len is it...levels have to be very, very, true always check.. all ways up..Gaz
And if your very very clever..you can mark all cuts to walls and floor so they line up..then do walls first and then floor so to reduce crap on floor...
a brave person who is confident to do it that way Dave.Very brave I opt for the easy option...thick dustsheets:grin:
newpark7,
len,
newpark7,
len,
