I bought a Vitrex 750 tile cutter the other day to cut some Wickes 600 x 300 x 9mm glazed porcelain tiles.
The standard blade chips badly so I also bought a Vitrex Hi Glaze blade 103406 which cuts better but still chips the edges a bit and has a bit of runout in it.
Is the runout in the blade likely to cause the chipping?
Any recommendations for a blade that will not chip or is it just what will happen with this type of tile?
If it's a blade I can go and pick up today that would be very helpful.
I've also tried cutting the tile both ways up and also tried covering it with tape first too but that seems to have little effect.
