Discuss Which Adhesive and pattern ? in the British & UK Tiling Forum area at TilersForums.com.
richardw
Hi Guys,
I'm about to lay porcelain floor tiles ( not polished - about 22 sq mtrs ) they are 600 x 300 and the room is 3m x 7m
Any suggestions on pattern based on previous experience ? I can see patterns like basketweave and herringbone as well as the standard brick - any thoughts ?
Also - will be laying these on concrete once I have the previous quarry tiles up - any recommendations on adhesive type/brand ?
Many Thanks
Peter Howe
I agree with Brian on this one, a random brick bond would suit this job ideally. As a bonus it cuts down on wastage too! With regards to adhesive I would always go with a flexible even on a concrete floor as it has an additive that give extra adhersion and of course you could always use a porcellbond adhesive which also has an additive. A solid bed 10mm notcheed trowel should do the trick, this will reduce down to approximately 6mm. As far as the grout joint goes I never go any wider than 3 mm. Any wider just doesnt loog good anymore and you dont want to detract from your tiles. It just looks classier. Hope this helps. Peter.
The Legend; Phil Hobson RIP
Mapei Keraquick 10mm max thickness, you can get pourable thick bed adhesive. Brick bond with 600mmx 300mm can be a pain, if there is any bowing in the tile, might be safer with third bond or quarter bond.
Also concrete is rearly flat enough to tile on direct, may need slc (self leveling compound) imo.:thumbsup: Good luck.
Gazzer
A few ideas 45 herringbone.jpg Half bond.jpg Herringbone.jpg quarter bond.jpg third bond.jpg Straight.jpg Straight 2.jpg
Reply to Which Adhesive and pattern ? in the British & UK Tiling Forum area at TilersForums.com
10 minutes ago Add bookmark #1 Which mapei adhesive ( it's convenient for me to buy this...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
